xendau
#1 Posted : Tuesday, June 2, 2009 10:37:44 PM(UTC)
xendau
How do you take out the compactor from under the sink area. I have tried just about everything and the left side just does not want to release.This was in our house long before we got here and we just want it out. Thank you for any help.:eek:
Russ12
#2 Posted : Sunday, August 8, 2010 9:49:34 AM(UTC)
Russ12
Take the drawer out and look up under the counter top. There should be screws holding the unit in place. Remove them and try again.
If this does not free the unit it may be that the flooring does not run all the way to the wall under the unit. In this case the compactor's feet are hitting the flooring edge, preventing its removal.
Try to adjust the foot pads by turning them clockwise to move the foot closer to the compactor's housing on both sides (note that some may be counterclockwise). This shouild free up enough space to allow the compactor to be removed.
ge Trash compactor pedal broken can't open (Trash Compactor Repair)
by tahoemark 7/25/2017 10:13:08 AM(UTC)
Trash compactor won't turn off (Trash Compactor Repair)
by fgg 8/23/2014 5:14:29 PM(UTC)
Trash compactor gears (Trash Compactor Repair)
by jfkeats 3/27/2014 1:59:16 PM(UTC)
Kenmore Trash Compactor (Trash Compactor Repair)
by verna2198 2/10/2014 4:47:46 AM(UTC)
trash compactor (Trash Compactor Repair)
by ld.rob@@yahoo.com 1/2/2014 9:51:28 AM(UTC)
broan trash compactor (Trash Compactor Repair)
by SPELLINGRA 6/17/2013 1:00:48 PM(UTC)
Trash Compactor Solid Pack does not function (Trash Compactor Repair)
by frd1952 4/3/2013 12:19:53 PM(UTC)
Whirlpool trash compactor limit switch keeps failing (Garbage Disposer Repair)
by bhorenkamp 1/10/2013 12:18:53 PM(UTC)
trash compactor motor stops (Trash Compactor Repair)
by oldschool51 1/2/2013 11:08:03 AM(UTC)
by oceanhill 10/20/2012 8:03:21 AM(UTC)
jenn-air trash compactor broken gear? (Trash Compactor Repair)
by mljdd 4/19/2012 11:02:49 AM(UTC)
GE Trash Compactor won't stay on (Trash Compactor Repair)
by ddecker 12/9/2011 9:34:07 AM(UTC)
GE trash compactor ram doesnt return to top (Trash Compactor Repair)
by jlarkins 8/1/2011 9:04:29 AM(UTC)
Trash compactor will not come up (Refrigerator & Freezer Repair)
by amalifeline 6/26/2011 4:02:55 PM(UTC)
trash compactor wont run automatically when i turn the rotary switch on (Trash Compactor Repair)
by jdituri 4/24/2011 7:05:07 PM(UTC)
