I need to locate an exploded diagram for a Fisher & Paykel "DEGXZ" dryer. I need to get into the interior to clean excessive lint from the inside surfaces.
Unfortunately only the manufacturer and their authorized servicers have such information.
Originally Posted by: redsuspender  I need to locate an exploded diagram for a Fisher & Paykel "DEGXZ" dryer. I need to get into the interior to clean excessive lint from the inside surfaces. take the two screws out ther are under white rubber plugs leftup top remove two screws in front remove panel reach in and pull assemble toward you clean and reinstall
