petermo
#1 Posted : Sunday, December 16, 2007 8:16:04 AM(UTC)
petermo
My gas Kitchenaid would not heat up this morning. Wife used it yesterday. everything seems to work ok but no heat.
kawfeeman
#2 Posted : Sunday, December 16, 2007 8:22:49 AM(UTC)
kawfeeman
need to check / ohm out TCO's ( thermal cut outs ).. could also be the hot surface ignitor..
petermo
#3 Posted : Sunday, December 16, 2007 8:41:55 AM(UTC)
petermo
do you mean the termal fuze?
kawfeeman
#4 Posted : Sunday, December 16, 2007 8:53:28 AM(UTC)
kawfeeman
yes , there are usually at least two thermal cutouts.. ( BTW: can you take the kick plate / toe kick off and view the gas valve / hot surface ignitor ?
misterfixall
#5 Posted : Sunday, December 16, 2007 6:32:21 PM(UTC)
misterfixall
the thermal fuse is at back .if its manufactured by whirlpool its white pastic about 1+ 1/2 inches lon with 2 terminals . test for continuity wih multimeter.
