losthelp
#1 Posted : Monday, June 1, 2009 1:30:03 PM(UTC)
losthelp
Have a maytag progforma pye2300ayw and it won't heat, otherwise runs normal. I check the conductivity of the Heater Element, HiLimit thermostat and the Thermal fuse and all were good. Any suggestions? Noticed it the b/c it ran for several hours and didn't dry the clothes???
thanks
UserPostedImage
#2 Posted : Tuesday, June 2, 2009 3:10:59 AM(UTC)
Here are your parts with a wiring diagram
Replacement parts for MAYTAG PYE2300AYW | AppliancePartsPros.com
Have you checked the power?
Sometimes you can loose half the line without actually tripping the breaker. Depending which side opens the unit will run but will not heat as the element requires the full 240 volts.
