I recently bought your replacement icemaker(AP178365).I just got around to installing it and it didn't work.There was power at the female plug in the back of the freezer,but none at the end of the icemaker harness.I checked for continuity on the black harness wire and there wasn't any.I assume the inline thermal fuse blew for some reason.Can I buy just the thermal fuse and install it with shrinkwrap?Also, what is the fuse failing temperature?
