WA_BELL1
#1 Posted : 16 years ago
WA_BELL1
Dishwasher stopped running in mid cycle. Appears that Control Panel is no longer available I think Pump & Motor is, not sure about timer, door switch etc..
What is the probability that it is the Control Panel which is bad versus another part ? How do I determine this ?
#2 Posted : 16 years ago
Replacement parts for MAYTAG DWU8270AAE | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16007823.pdf
First determine is the unit totally dead or what???
Many things could cause this.
First make sure the unit is getting power. Check the circuit breaker or fuse box.
The best way is to use a meter and check at the dishwasher.
Could be a bad receptacle or a bad connection in a wire nut.
Next would be the door switches. These can be checked with a meter with the power off using ohms to make sure they close when the door is closed
Maytag dishwasher dead (Dishwasher Repair)
by archer75 7 years ago
Maytag Dishwasher Dead in the Water (Dishwasher Repair)
by Mr B 12 years ago
by dadofthree 13 years ago
