Installed a control module in our Maytag SHU5306UC sometime within the last 2 years and it has been working fine as ever. Today, however, I got an odd whiff and happened to look over at the washer which I had started a short while earlier and noticed there was no LED light on. I didn't think the cycle was over and even if it was I thought the "CL" would still be showing. I opened it up and the dishes were hot and seemed to be clean. After closer inspection they were not uniformly so. I closed the door and pushed the start button but nothing happened. Would you know what might be amiss or could you start me down a diagnostic path? Thank you!
Sorry. This is regarding a Bosch unit, not Maytag (I've got a Maytag washing machine that's also acting up) Thanks.
