My refrigerator is not getting cold but my freezer is working great, does anyone have any ideas.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open.
OR If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer(adaptive defrost control), defrost heater, defrost thermostat
If the heater and thermostat are ok it’ll be the control.
