redi
#1 Posted : Friday, December 14, 2007 2:54:36 PM(UTC)
redi
The washer will fill, agitate and drain, but when it is time to spin the clothes, I have to manually put my hand in the tub, and "force" it to go around, it feels like it is "stuck" on something. Once it is unstuck, and give it a little push, it picks up speed and starts to spin on its own.
#2 Posted : Friday, December 14, 2007 3:56:22 PM(UTC)
Remove the front panel and check the belt and the transmission pulley.
If there is nothing wrong then the transmission is bad and has to be replaced.
- The part number for the belt is AP3867042
- The part number for the transmission pulley is AP2107024
- The part number for the transmission is AP3892126
- Here are the break down diagrams for the Frigidaire washer Model FWS445RFS3
