ok so one of my children left my mini fridge door open after getting some water. I noticed a lot of ice build up and turned it off to thaw out. I couldn't wait and started using a chisel to get the ice out. Big mistake!! I hit the bottom of the little freezer section and freon came spewing out. Question....can I still use the refrigerator (I never used the freezer at all, or is this something that will take a reapir. And if it does take repair any idea how much it will cost me? I think I spent about $150.00 on the mini fridge to start with. It is only used to keep water chilled. Is there a quick fix or a way I could do it myself? I'm very handy just a little impatient.
Thanks for any help afforded me.
The best solution is to buy a new fridge. It's not worth to fix.
