Oven shuts off when the pre heat temp has been reached . Example: the Temp is set at 350 . When this temp is reached the oven shuts off.
Most likely the problem with your range is a bad control board. - The part number for the control board is AP2125564 You might need the overlay too. - The part number for the black overlay is AP2552241 Gene.
