It seems that my particular model oven is around 10 years old, and I am unable to purchase a replacement exterior door glass. Can anyone help me find a compatible part? I am speaking of the exterior frosted glass.
Quote:Can anyone help me find a compatible part? If there was a compatible part the manufacturer would have substituted the original part number (316089003 aka AP2125339) to it, not discontinued it. Unless you can find someone with old stock of the original still kicking around (don't hold your breath), you are likely SOL. The almond version of that glass is still available (see the following link). I don't know how it would look on a white stove though. LINK > Outer Oven Door Glass, Almond (no picture) Lastly, you might be able measure the size it needs to be and get a piece of glass cut and tempered. It will be clear but at least the oven would then be able to be used safely. JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
