LG stove want work, code F-7 keeps coming up after i keep reset it by unplugging, the instruction said replace PCB Assembly, however there is about 3 pcb boards. Also,how do you check each one to witch to replace?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
F-1 code on lg stove electric
