Yesterday I moved this refrigerator from my Daughters house to her new house, approximately 2 miles. Everything was working fine until I moved it. Now everything works except the icemaker! It was only unplugged for about 1 hr! It has the "in the door" icemaker, with the LED Lights. I have no lights flashing, but the water works in the door to fill glasses, etc. I removed the line from the valve to the icemaker and it is unobstructed - - Can you help ??? Is there a reset or something?? The temp in the freezer is 10 degrees - - Thanks !!
does your ice maker have a metal wire connected to it , is it in up or down position ? if so push it down. or it might have an off/ on power switch
No wire - It does have an on off switch, which is basically a slider switch that opens a window for the led light - - I moved it to on, but nothing happens and no led light - -
sounds like the pc emitter boards have failed , one with flapper door + one with led , they come together
