lstone
#1 Posted : Tuesday, November 15, 2011 10:23:29 AM(UTC)
lstone
Ice maker has been dripping water into the ice bin for years causing the ice cubes to freeze in a block. Seems to be getting worse.
misterfixall
#2 Posted : Tuesday, November 15, 2011 12:14:35 PM(UTC)
misterfixall
sounds as if too much water is coming into icemaker causing the excess water to over flow into ice bin. it might be either a problem with icemaker demanding too much water, or water valve at back of fridge , try shutting off your ice maker, with the tray empty, for a few days +see if water seeps into icemaker , if so problem would be with water valve,due to leaking water valve seal, if not possibly ice maker is at fault
lstone
#3 Posted : Thursday, November 17, 2011 5:06:09 AM(UTC)
lstone
Did not work. Changed valve and still leaking. Can see frozen stream coming out of fill cup. Andy other suggestions?
