I recently changed the water filter and the water comes out very slow. Tried another filter same thing. Put old filter back in -same thing. Repair man showed ther was no problems with the water line up to where it enters the refrigerator. He thinks it is the solenoid but my feeling is if it were the solenoid I wouldn't be getting any water at all. Ice works fine. I did exert upward pressure when I installed the filter and after reading the directions I know I wasn't supposed to do that. HELP
It can be the water valve (#800 on the diagram) if it has hard water deposits built up inside. Gene.
