Last week as the washer was running my son turned the timer knob while itwas still pulled out and running. This made the washer pop it's breaker. After Ireset the breaker it finished its' cycle just fine. I went to do a load a fewdays later and now it will not fill with water. If I move the knob over it willrun the rest of the cycle. Just will not fill up with any water. no hot nocold, I made sure the water was still on, and that the lines were not clogged. please help......:confused:
This is really messed up as it should not start until it is filled with water so it can be the water level switch or the timer/control unit. You might have to replace each one, one at a time to find out.
If you need more info please post a model number so we can see what machine you have.
