Making Ice fine but no water from dispenser.I hear a relay click when I open the switch.I suspect the motherboard in back but not sure.Help if you can,Thanks:)
Since you hear what may be the water inlet valve on the back working,you can disconnect the line there and see if water comes out when you try the dispenser. If it does your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
