I have a very similar control board. Same etched number 6105015, but with a connector at P2 (it is un-used though). W10184875 (AP4359010)
I have the same two built resistors R23 and R22. Did you every get the correct parts identified? Did it fix your issue? The dropbox links are dead at this point. Any idea of the cause?
Thanks!!!!!
