GEARHEAD
#1 Posted : Monday, May 25, 2009 1:04:26 PM(UTC)
GEARHEAD
Gas Dryer tumbles but no heat. What should I check for?
sidfink43
#2 Posted : Tuesday, May 26, 2009 5:00:09 PM(UTC)
sidfink43
First check for continuity in your thermal fuses and thermostats.
If they all check out, you probably have a problem in your gas ignition/flow system.
Here is the service manual
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
Good luck and let us know what you find.
GEARHEAD
#3 Posted : Wednesday, May 27, 2009 4:47:23 AM(UTC)
GEARHEAD
I tested the fuse and flame sensor...good. I removed the igniter and applied 110v direct to it and it didn't warm. I then replaced the igniter and system is working correctly.
Thanks for the feed back!
sidfink43
#4 Posted : Wednesday, May 27, 2009 5:14:18 AM(UTC)
sidfink43
Great, glad you got it fixed, and thanks for updating us.
Maytag no heat (Dryer Repair)
by xenon68 7/15/2010 10:31:06 AM(UTC)
