I have and intermintant F7:EO error code on my gas Oven/Stove control panel. What does this code mean? What part do I need to order? How hard is it to install? Thanks in advance for any help. Rob rwreedspeed@yahoo.com
The error code "F7:E0" means "Invalid latch switch reading". The first thing I would do is check the interlock switch on the door latch and the door latch itself (the door latch assembly is located on the back of the range). The interlock switch must be closed when the door is locked. If there is nothing wrong, then check the wires from the switch to the control board. If wires are fine then replace the control board. - The part number for the interlock switch AP3133062 - The part number for the oven lock assembly AP3178818 - The part number for the control board AP3085557 - Here are the break down diagrams for the Kitchen Aid range Model KGRT600HBL6Gene.
Gene, Going to dive into that this weekend. Thanks, Rob
Keep me updated, please.
Hi, since the symptoms of my Superva oven when it displayed the fault code F7 E0 were the same as a failing gas oven bake igniter, I replaced the igniter and no more error code. Oven works as it's supposed to now!
