My electric Jennair wall oven started beeping and the control panel was partially unresponsive - no error codes. I turned off the circuit breaker for five minutes. When I turned it back on the oven worked fine for 15 mins. then shut down completely - no light, no fan, no display, completely unresponsive. I turned off the circuit breaker over night, but it is still the same. Is the "brain" shot? What part do I need? Is it the clock, as I've seen in other posts, or could it be the relay board? How can I find out without calling a repairman? I've done a lot of electrical wiring so I can follow your instructions. Thanks so much - the Christmas cookies are waiting to be baked!
The first thing I would check is the incoming and the outgoing power on the power board in accordance with the service manual. Most likely the problem is there. - Here are the break down diagrams for the Jenn Air oven Model JJW9527AAW
