rlittle
#1 Posted : Wednesday, December 12, 2007 3:51:21 AM(UTC)
rlittle
side by side that makes ice very slowly and puddles water intermittantly underneath on freezer side. any ideas on how to fix this problem?
#2 Posted : Wednesday, December 12, 2007 10:23:26 AM(UTC)
The first thing I would check is the drain under the evaporator coil in the freezer for clog.
What is the temperature in the freezer?
In order to provide the most accurate advise I need the complete model number of the fridge.
rlittle
#3 Posted : Wednesday, December 12, 2007 11:31:15 AM(UTC)
rlittle
freezer is cold, ice maker does not make ice like it used to and icecube is small not fullsize. could the copper waterline be cracked? i do not see water underneath the fridge all of the time. will get serial number from refrigirator tonight and post up.
#4 Posted : Wednesday, December 12, 2007 11:50:07 AM(UTC)
How cold is the freezer?
It suppose to be about zero degrees for the ice maker. Just a few degrees warmer will cause the ice maker to slow down.
The best thing is to measure the temperature, using a refrigerator thermometer.
