tksnyder
#1 Posted : 16 years ago
tksnyder
Ice dispenser chute door wont close. Inside freezer frosting up. Can anyone tell me how the front cover comes off so I can see inside to see what broke? Does it snap on, or slide up to remove? i dont want to break it removing it?
TechnicianBrian
#2 Posted : 16 years ago
TechnicianBrian
The front of the dispenser comes off by snapping it loose on the bottom. If you look up at the bottom, you will see two slots about the size of a flat blade screwdriver. Push downward on the bottom while pulling forward with the screwdriver and the face will come off. Unplug the refrigerator and disconnect any wiring to get to the paddle mount plate which is held in place with two screws, and/or two clips. Then you should be able see the problem.
