The ice maker is no longer producing ice. I can get the water to the fountain in the door, but nothing to ice maker. I changed the water valve thinking that I was not getting water to the ice maker from there, this did nothing for me. Would anyone have any ideas on a troubleshooting process to try to isolate the problem?
Mike
If you remove the front cover off the icemaker you will see test points. This page will explain in detail how to use them. I know it says whirlpool icemaker but you have that type icemaker on your refrigerator. Whirlpool Icemaker Repair Guide
It appears as though the motor module is bad. I was able to get water via the "V" to "L" jump, but there was no cycle with the "T" to "N" jump.
What do I need to replace to get this to work?
Thank you for your help on this. Maybe I can get by without indiscriminately replacing the entire refrigerator!
Mike
The motor module part number 628366. Note that the whole ice is does not cost much more than this part. Whole icemaker part number 1129313.
