ewoevo
#1 Posted : Tuesday, December 11, 2007 7:32:08 AM(UTC)
ewoevo
My control panel isn't working. Last night it just stopped working and has the dislpay of 88. The right 8 also has a vertical line in the top half of the number. None of the controls on the panel work. The stovetop works fine. I tried unplugging it from the wall and that didn't reset anything. I also called the Maytag repair line and they weren't any help.
#2 Posted : Tuesday, December 11, 2007 2:33:10 PM(UTC)
Most likely the problem with your range is a bad control board (aka clock).
- The part number for the control board AP3503539
perham8
#3 Posted : Sunday, May 4, 2008 4:43:31 PM(UTC)
perham8
Can you provide instructions to replace the control board. Mine crapped out too. I have the part (I bought from APP)...just need some guidance. Thanks.
#4 Posted : Monday, May 5, 2008 11:11:41 AM(UTC)
perham8,
What is the complete model number of the range?
perham8
#5 Posted : Monday, May 5, 2008 12:06:12 PM(UTC)
perham8
Model #: MGR5750ADW
Serial #: 19053688YK
#6 Posted : Monday, May 5, 2008 12:09:42 PM(UTC)
Just remove the cover on the back of the control panel and it's all yours.
Here are the break down diagrams for the Maytag range Model MGR5750ADW
perham8
#7 Posted : Saturday, May 10, 2008 9:18:45 AM(UTC)
perham8
Thanks Gene,
I'll give it a try.
Guest (4)
