Mr.Kenneth
#1 Posted : Thursday, May 21, 2009 10:31:41 AM(UTC)
Mr.Kenneth
The dishwasher is loud during washing and it used to be very quiet. I read another post about water level not high enough in washer. So, I filled it up a little below the heating element. It seems to have solved the sound problem, but what is causing the low water level. I already checked to make sure the screen was clean on the water input. What are some of the other options for me to check. Thanks.
thebigwilli
#2 Posted : Friday, October 23, 2009 6:27:30 AM(UTC)
thebigwilli
I am having the same problem with mine. ge trition xl mod#gsd6260j00ss i have check the valve screen it was fine it seems like the valve shuts off flow of water prematurely i have yet to figure out what is causing it.since then my normal wash light and heated drylight wont illuminate as well??does anyone know what controlls the amount of water to fill basin??
