tigerpilot
#1 Posted : Monday, July 30, 2007 2:44:25 PM(UTC)
tigerpilot
Maytag electric range CRE9600ACE. The oven is 175 degrees COLD at 450. (reads 275 on a good oven thermometer). Sensor resistance is O.K. (1100 ohms @ 85 degrees – 1600 ohms @350 degrees) Tested it in a different oven at 350 degrees. Grids glow in “Broil” and “Bake.” I am thinking the problem must be in the clock module.
Any other ideas cheerfully considered.
Thanks, Don
Adam / APP Team
#2 Posted : Monday, July 30, 2007 4:40:50 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
It sounds like it may be one of the relays in the control. In this case you would have to get the clock control as one piece.
tigerpilot
#3 Posted : Monday, July 30, 2007 4:53:42 PM(UTC)
tigerpilot
Thanks...I am thinging of having rebuilt by CG industries. About $115
Thanks, Don
