papavan
#1 Posted : Thursday, May 21, 2009 8:57:33 AM(UTC)
papavan
Recently, we started to get pieces of plastic in the ice dispenser. Thought we ordered the right part Ice bin auger drum - replaced and tested. Now the ice will come out as cube only. In the crush mode it still dispenses cubes. Any suggestions?:confused:Ice Bin Auger Drum
woodchuckie
#2 Posted : Thursday, May 21, 2009 12:05:10 PM(UTC)
woodchuckie
I don't think the augur has anything to do with it.You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
Parts 3,33, 37 are some of the parts involved on diagram 8. Replacement parts for WHIRLPOOL ED25QFXHB00 | AppliancePartsPros.com
papavan
#3 Posted : Thursday, May 21, 2009 12:43:55 PM(UTC)
papavan
Your correct. The spring was not loaded right and I had also forgot to put part 30 in it's proper place.
Thanks for your help.:)
Need Help Replacing Ice Bin Auger Drum (Refrigerator & Freezer Repair)
by jchncsu 11/6/2008 5:34:25 PM(UTC)
