danfrank
#1 Posted : Tuesday, December 11, 2007 4:28:55 AM(UTC)
danfrank
My ice maker only make hollow ice... It has alwasy done this. It is getting worse. Do I need to replace the ice maker or the water valve????
#2 Posted : Tuesday, December 11, 2007 1:57:02 PM(UTC)
Such problem could be if there is insufficient temperature (more then 3-5 degrees) in the freezer or there is not enough water for the ice maker.
The first thing I would do is check the temperature in the freezer. Normally it suppose to be about zero. It it's more - adjust the temperature control.
Post your findings.
hollow ice cubes after other repairs (Refrigerator & Freezer Repair)
by mydood1900 8/23/2021 7:59:58 AM(UTC)
ice maker makes hollow ice (Refrigerator & Freezer Repair)
by doggydog 1/3/2018 3:07:27 PM(UTC)
hollow ice slow water dispenser (Refrigerator & Freezer Repair)
by faulkkev 7/6/2014 8:14:24 AM(UTC)
Water line snapping and water only trickles, no or hollow ice (Refrigerator & Freezer Repair)
by ladyred1101 10/13/2010 11:04:30 AM(UTC)
few and hollow ice cubes (Refrigerator & Freezer Repair)
by Mikeyy 4/23/2010 7:03:22 AM(UTC)
by kimshow 2/23/2009 4:42:01 PM(UTC)
by mdevore 5/25/2008 9:21:54 PM(UTC)
ice maker hollow ice (Refrigerator & Freezer Repair)
by eaton11727 3/16/2008 8:40:44 AM(UTC)
dispensing water, but no ice...also hollow ice (Refrigerator & Freezer Repair)
by chrisbinparadise 2/25/2008 7:40:40 AM(UTC)
