The ice maker is dripping into the ice bin and causing the ice cubes to freeze solid to the auger, hence the auger can't turn to dispense the ice.:confused:
[FONT='Times New Roman'] The most common thing to cause this is that the fill tube or the fill cup gets clogged up with ice. If this is the case remove all the ice and replace the water valve. Refrigerator Leaking Repair Guide[/FONT]
