Removed oven door and replaced innermost glass. Now trying to put oven door back together and hit snag. Can't remember how to install oven glass next to outer glass. Top seems to fit in flange in heat shield, but can't figure out how to secure bottom of glass.
Originally Posted by: magician59  I have look at that numerous time. It does not show where or how to place the inner glass door #10. It merely shows it as a piece of glass, next to and parallel witht the other piece of glass. Thank your for your attempt to help.
magician59 did you ever figure this out? I am having the same issue trying figure out how that goes back.
Thanks!!
It's been an awful long time since I had a door to replace glass on. I'm afraid I can't be of much help in this case. I would have to have methodically disassembled the door in order to get things back together.
