kjnowicki
#1 Posted : Monday, December 10, 2007 1:34:15 PM(UTC)
kjnowicki
Hello I have a Oven Problem I need to get some Info on I'm thinking the Glow plug for the oven went out.When turning on the oven i hear the clicking at the control nob to start the heating of the glow plug but nothing happens and i don't see any light from the plug when i turn on the broiler it starts to glow the a click from the gas to ignite.So my question is does this sound like a glow plug gone bad? any advice would be great :)
#2 Posted : Monday, December 10, 2007 5:46:17 PM(UTC)
Check for 120V coming to the igniter (#28 on the #3 break down diagram)when the control calls for the heat.
If there is 120V then replace the oven igniter.
If there is no 120V then replace the control board.
- The part number for the oven igniter AP2014008
- The part number for the control board AP3187700
- GE XL44 parts - replacement parts for all XL44 models.
- Here are the break down diagrams for the GE range Model JGBP28BEA6WH
