Machine stopped dropping ice in bucket. Clicking sound heard when motor tries to rotate the cubes out. Water fills again causing overflow. Please advise. Ice maker is turn off for know.
The problem could a bad ejector, a worn out gears or a bad motor. The correction is to replace the ice maker. - The part number for the ice maker is AP4299334Gene.
