stacey.bartell
#1 Posted : Tuesday, May 19, 2009 6:56:42 AM(UTC)
stacey.bartell
The dishwashwer wont start, no light on the keypad for start/reset, the arrow pads are not working. Can you guide me to what is wrong? module, or keypad or any parts that I should check to replace?
#2 Posted : Tuesday, May 19, 2009 2:59:17 PM(UTC)
Make sure there is 120VAC to the dishwasher.
Remove the toe panel and check the power cord connection to the dishwasher for burned wires. Check all wires inside the door.
Look for an envelope with the tech sheets under the dishwasher or inside the control panel. Perform the troubleshooting as instructed in the tech sheets. Post the results.
Here are the breakdown diagrams and Replacement parts for GE PDW9700J00II | AppliancePartsPros.com
