I have 3 leg power cord and the house I moved into has a 4 pronged power outlet. Can I install a new cord with a red ,black, white. & green wires. My dryer only has black , white, & green legs. If so where do I connect the red wire to in the back of the dryer?
Can I install a new cord with a red ,black, white. & green wires. My dryer only has black , white, & green legs. If so where do I connect the red wire to in the back of the dryer? Cannot say without a Model Number Is this an electric dryer that runs on 240 volts? The reason I ask is that the color code on most 240 volt dryers is, L1 = Black, L2 = Red , Neutral = White A Model Number may help to ensure you have the correct wiring. The following may help. http://www.applianceaid.com/electrical_testing_tips.html |
THIS FORUM IS DEAD!!!!!!! |
