dryer runs but does not have heat. have checked and found that the heating element has no ground. have added a ground wire to the orange wire and the heater element get hot. where does the heater element get its ground from
Here are your parts Replacement parts for WHIRLPOOL TEDS740PQ1 | AppliancePartsPros.comHere is a wiring diagram https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576793.pdf have added a ground wire to the orange wire and the heater element get hot. where does the heater element get its ground from It does not have a ground!!! You are very lucky as you have added a short to the unit and could of had a huge arc & spark. REMOVE THAT GROUND WIRE ASAP.The heater runs on 240 volts and is not connected to ground. Check the Thermal Cutoff, Operating Thermostat, High Limit Thermostat all should be 0 ohms at room temperature. Also when in a cycle Timer Switch 2 should be closed. Remove a wire from one side of any device you are measuring to ensure that you are not reading an alternate/parallel circuit path. One of the above is open for sure as if all were OK you would have a dead short from L1 to ground and of coarse a lot of sparks/flames. Be sure to unplug the unit when working on it. |
THIS FORUM IS DEAD!!!!!!! |
