Aaron Felty
#1 Posted : Monday, December 10, 2007 10:23:29 AM(UTC)
Aaron Felty
The blower was broken and it had a plastic screw cap over some metal nut(?). I broke off the plastic to reveal the metal nut and now the blower housing cannot come off (it is fine). How do I put the new blower which has a small but built into it or how do I get that old nut that was on the post off so I can put the new blower on the post from the motor?
Thanks, Aaron
#2 Posted : Monday, December 10, 2007 4:26:19 PM(UTC)
If you can make and post a picture it might help to provide the better advise.
#3 Posted : Tuesday, December 11, 2007 2:43:16 AM(UTC)
Bust off all of the blower plastic around the nut, then remove motor. Put an adjustable wrench on the motor pulley end and a pipe wrench on the nut.I think this is a left hand thread so turn the nut clockwise.
Aaron Felty
#4 Posted : Tuesday, December 11, 2007 12:10:40 PM(UTC)
Aaron Felty
Thanks Gene,
I just removed the motor and was able to hold the nut on the backside of the motor and unscrew that crazy metal nut. Thanks for your suggestion. Aaron
