posejpal
#1 Posted : Monday, May 18, 2009 8:44:01 AM(UTC)
posejpal
When dishwasher is running , get error message "blocked wash arm". Even get message when running empty dishwasher. Nothing is blocking arm and drain hose is ok. What could my problem be??/
#2 Posted : Monday, May 18, 2009 1:29:14 PM(UTC)
Make sure all holes in the spray arm are open.
Remove the lower spray arm and the top part of the pump. Remove the pump filter (#6 on the diagram) and the rinse arm assembly (#7) and clean them using white vinegar and a soft metal brush.
Here are the breakdown diagrams and Replacement parts for MAYTAG DWU9962AAM | AppliancePartsPros.com
blocked wash arm (Dishwasher Repair)
by ddmenco 12/11/2012 9:13:28 PM(UTC)
Blocked wash arm error (Dishwasher Repair)
by musie 6/15/2009 3:35:31 PM(UTC)
