beverlyjean
#1 Posted : Monday, May 18, 2009 5:44:22 AM(UTC)
beverlyjean
My Dryer Will Start.. Gets Hot.. But Stops Completly After Running For 5 Minutes Or So....what Could Be The Problem... And How Do I Repair This...and It Seems Like The Drum Is Turning Hard....
#2 Posted : Monday, May 18, 2009 12:06:45 PM(UTC)
Were you able to restart the dryer right after it's stopped? Did it make a humming noise? If the first answer is "No" and/or the second answer is "Yes" then the problem most likely is a bad motor.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER4634EQ0 | AppliancePartsPros.com
beverlyjean
#3 Posted : Monday, May 18, 2009 12:30:40 PM(UTC)
beverlyjean
what is the motor number and how much is it
beverlyjean
#4 Posted : Monday, May 18, 2009 12:31:59 PM(UTC)
beverlyjean
how do i get to this motor......from the back of the dryer or the front
#5 Posted : Monday, May 18, 2009 3:42:29 PM(UTC)
The part number for the motor is AP3094245. You have to remove the front panel and the drum to access the part.
You can find the complete instructions in the Service manual.
