2 Pages<12
dignome
#11 Posted : Wednesday, June 2, 2010 12:02:27 PM(UTC)
dignome
Hi. We had this problem as well with our calypso whirlpool washer. It turns out the extended spin button was stuck. This was verified with an ohm meter. I ended up replacing the control panel assembly (part with the buttons and the lcd screen).
The part number is 8299673 8563810.
Found one used for $30 on a certain online auction site!
calvin200
#12 Posted : Wednesday, July 28, 2010 5:57:54 PM(UTC)
calvin200
You gave two part numbers. I'm going to check them up, but did you do both or are there two different part numbers for the same part?
Guest (6)
2 Pages<12
