Our GE Profile dishwasher has been getting louder and louder for a while. It's almost 5 years old. The noise comes & goes while it's running. It sounds like a loud rumbling sound. Kinda like a rock tumbler.
I suspected those wings or blades that spray the water being loose. They spin free and have some wobble but I dont see any way to tighten them.
Also, it's beginning to leave some soap in the dispensor when its done. That seems weird.
Thanks in advance. Mark
Here are your parts Replacement parts for GE PDW7880J01SS | AppliancePartsPros.comI suspected those wings or blades that spray the water being loose. They spin free and have some wobble but I dont see any way to tighten them. Some wobble is normal. There is no way to tighten them. Also, it's beginning to leave some soap in the dispensor when its done. That seems weird. It is not pumping the water properly so it just is not spraying enough at the soap dispenser to flush out the soap. Remove the center cover in the unit and check for debris in the sump. Could also be that it is not filling to the correct level, unit will then suck air through the pump, cavitate and make a growling noise. Most units fill to just under the heating element. One way to check is stop it after a fill and check the level. Also can add a couple quarts of water if the growl reduces frequency or disappears then low fill is the probable cause. If above applies Probably the screen filter on the input side of the water valve is partially plugged. Remove the valve and clean the screen. Do not remove it, it is there to keep crud out of the valve, which could hold it open and cause a flood. Also a good idea to drain some water out of your hot water tank. Let it run till the water is clear. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the great info. I'll check into those areas asap.
The parts & schematic screen is wonderful. Can I search for my fridge on there too?
I wish I had found this forum years ago.
Can I search for my fridge on there too? Yes
Hope the info gets it fixed for you! Good luck |
How do I get to the filter? Do I have to pull the unit out of its happy home and get to the back side?
Again, great site. I love the schematic and parts pages. I'm a service rep who works on office machines. I'm going to show your site to our SME (subject matter expert) guy and see if we can re-do our parts books in this format.
The water inlet valve is just behind the kick plate on the left hand side. You should not have to pull the unit to work on it. |
