lone-rider
#1 Posted : Sunday, December 9, 2007 5:25:17 PM(UTC)
lone-rider
Frigidaire front loader will not spin, but it will go through all other cycles and pumps out water.
ApplianceJunk
#2 Posted : Sunday, December 9, 2007 7:11:03 PM(UTC)
ApplianceJunk
Check the door lock switch.
JEFFREYROBERT
#3 Posted : Tuesday, December 18, 2007 2:16:28 PM(UTC)
JEFFREYROBERT
I Have The Same Problem With The Same Model Machine. Checked Door Switch. It Appears To Work Becuase With The Door Open It Will Not Fill With Water.
kawfeeman
#4 Posted : Wednesday, December 19, 2007 4:54:19 AM(UTC)
kawfeeman
im not sure the machine should fill with the door open ?
JEFFREYROBERT
#5 Posted : Wednesday, December 19, 2007 3:49:09 PM(UTC)
JEFFREYROBERT
My Frigidaire Washer Does The Same As Lone-rider's Does. It Will Go Through The Fill Cycle, Wash Cycle But Drum Doesn't Turn. Drain Cycle, Etc. Won't Spin At All. Belt Is Good. Motor Doesn't Smell Burn't. When I Said I Checked The Door Latch I Opened The Door And Set The Washer To The Fill Cycle And Nothing Happened. I Then Shut The Fill Cycle Off. I Closed The Door And Turned The Fill Cycle On Again And This Time The Washer Started To Fill. That Is Telling Me That The Door Latch Must Be Working. I Don't Have A Wiring Diagram For This To See If The Latch Is Tied In Some Other Way. I Would Appreciate Any Other Advice. Thanks.
#6 Posted : Thursday, December 20, 2007 7:31:45 AM(UTC)
Frigidair has a fine chain diagram for this failure in the service manual underneath
It includes checking the soap dispenser magnetic switch, the timer contacts and the door latch. Door latch must lock before spin is enabled.
Guest (4)
