golfpro1
#1 Posted : Saturday, May 16, 2009 3:56:52 PM(UTC)
golfpro1
Icemaker continues to ask for ice and does not stop.
woodchuckie
#2 Posted : Saturday, May 16, 2009 4:21:28 PM(UTC)
woodchuckie
The water keeps running in to the ice maker? Water inlet valve on the back where the water supply come in is stuck open.
izzy9213
#3 Posted : Saturday, May 16, 2009 4:24:11 PM(UTC)
izzy9213
My Ice maker is making ice but seems that when you press for the dispenser to get ice you can hear it rotate but will not dispense any suggestions?
woodchuckie
#4 Posted : Saturday, May 16, 2009 4:29:53 PM(UTC)
woodchuckie
Open the door and hold the door switch in and push the ice dispenser lever. Look to see if the augur is actually turning. If it is you may have clogged ice in the tunnel where the ice goes. Does your door flap open. Do you hear the motor but the augur doesn't turn.
izzy9213
#5 Posted : Saturday, May 16, 2009 4:42:41 PM(UTC)
izzy9213
When I do that I can hear the auger turning, I have check to see if there is ice clog but I have clean out the ice and allowed it to make some more but the seems that the auger is not catching on to the back of the ice tray that pushs the ice
izzy9213
#6 Posted : Saturday, May 16, 2009 4:53:26 PM(UTC)
izzy9213
The flap door opens and the auger turns but it seems that it is not pushing the ice ?
