blade
#1 Posted : Saturday, May 16, 2009 8:30:38 AM(UTC)
blade
I have a GE side by side and here are the issues: If I turn off the freezer and crank up the fridge nothing happens, if I turn on the freezer to the lowest setting it will run ( never shut off ) and will not freeze, just get cold and when you open the doors the middle ( in the front ) it is too hot to touch. any thoughts ?
woodchuckie
#2 Posted : Saturday, May 16, 2009 8:35:46 AM(UTC)
woodchuckie
Check the condenser fan which is around back at the bottom near the compressor. It should be running when the compressor is.
The fridge side is cooled by the cold air in the freezer. The air is blown through a vent by a fan in the freezer. So that part of your description is normal.
#3 Posted : Saturday, May 16, 2009 10:13:37 AM(UTC)
Here is a good site with fridge info
http://www.applianceaid.com/refrigerator.html
Check out #18
Also make sure the condenser coils and fan blade are clean
blade
#4 Posted : Friday, May 22, 2009 1:14:40 PM(UTC)
blade
The fan is not running so i tried replacing it, however still not working
blade
#5 Posted : Friday, May 22, 2009 1:58:46 PM(UTC)
blade
update - I am not getting the proper voltage on the output ( Red to White is only 5V ) am I to assume that it is the control board ?
AIMANNY
#6 Posted : Friday, May 22, 2009 2:24:08 PM(UTC)
AIMANNY
you may have an comp board problem ------------part 801
and clean your condenser.
