Rank:: Member
I have a dual cooling wine cabinet, mahogany effect, that was brought as a gift 7/8 years ago from Scotts of Stow. The lights in both sides flicker so some power is going in but there is no cooling at all. Have tried speaking to SofS and they don't sell them anymore and can't help. The cabinet is like a piece of furniture but can only be used for storing wine but not for cooling as intended. Can anybody out there help?
I cannot be of much use. Hopefully someone else will jump in with info on this unit. Without a model number finding any info will be impossible. Even with a number it is doubtful. This is a US site so info on UK appliances is scarce. Here is a good site with help on fridge repairs though your p0wer will be different. http://www.applianceaid.com/repair-help.htmlCheck the back of the unit there is usually a cardboard cover that will let you get at the compressor etc., remove the cover. Unplug the unit and the connection to the compressor to see if your lights will now come on full. If they do then it could be a compressor or it's start device problem. |
THIS FORUM IS DEAD!!!!!!! |
