rockmacc
#1 Posted : Saturday, May 16, 2009 2:28:34 AM(UTC)
rockmacc
Ge motherboard part # mix up?
Ge pds22mfsaww bottom freezer
Order Date: 05/12/09
Order Number: 673294
part #AP4297272 (WR55X10656) Main control board assembly domesti
this one looks exactly like mine on your site
Board #200d4854g014 this is the one I ordered # diff 4
The one shipped #computime 200d4850g014 # diff 0
The part # is the same but they have different # on the board and are very different
I will attach the pictures if I can thanks rock
Rocker switch S136.doc (28kb) downloaded 19 time(s).
rockmacc attached the following image(s):
george747
#2 Posted : Tuesday, June 15, 2010 1:21:42 PM(UTC)
george747
My situation is just the opposite. The board I removed from my refer is like the lower photo and it has 5 plugs on the right side. The board I was sent is similar to the upper photo with only 4 plugs on the right. The box was labeled W55x10942 but the board doesn't look like any of the photos of similar boards on the web. There is no J-5 and a lot of components are not there, just a bunch of jumers. Also, the board I received has one less relay. A schematic I have says J-5 is for the Quick Chill (somethng-can't read it). My refer is a PSI23SGNA. Was my box mismarked or wrong bord inside? Numbers on the board are: EBX1110P003; 94V-OOPCVO; 702130401.01GA and SWS 1048 (rev 1).
A sticker on the board has the following codes: WKKT 1304-00-00; 200D6221G009 and R102FC 3706DG. Anyone got a clue?
fhwood
#3 Posted : Saturday, July 2, 2011 9:22:42 PM(UTC)
fhwood
My old motherboard (MB) number is WKKT 1304-00-00 & the one I received is WR55X10942. Is the new MB the correct replacement for the old one?
Whenever I check to see if another MB should be used, the new one is the one that shows up.
If so, how do I connect to the new MB since it has more connectors than the old one?
Flynn
#4 Posted : Sunday, July 3, 2011 2:49:27 AM(UTC)
All parts sites deliver the WR55X10942, a redesigned board that's probably more reliable.
It is pretty hard to miss-wire the new board, just plug in all the connectors into the new board where they where on the old board and ignore the other sockets on the new board.
