AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Water leaks out after tub is filled at any level
My Kenmore top loader fills with water and starts to agitate.At the same time I can see water leaking out of drain hose ... till it gets low enough that is is too low for clothes level.Would this be some type of solenoid for draining or switch?? Any help is appreciated.:) :) :)
How high the drain hose goes? What is the complete model number of the washer?
Gene thank you for asking I am at work and dont have the model number right now.I should have said drain out because it actually drains thru the proper tubing after the washer fills.It has operated properly for the last 3 years and is about 10 years old. I will get the information as soon as I get home.Its 1:50am Cincinnati Ohio time now .I will be home in6 hours .Again thanks for replying:eek: :)
Washer Repair
