Lawrence430
#1 Posted : Thursday, May 14, 2009 12:00:55 PM(UTC)
Lawrence430
I need to replace the compressor for Amana refrig Bottom Freezer model #BRD18V2S, Mfg#P1326504WS, compressor #12049717 which is discontinued. Your site says to replace that discontinued compressor with the compressor #AP3179961.
The old compressor has three ports: suction, discharge and a process port. The picture of your replacement compressor has the above three ports PLUS 2 additional ports at the bottom of the compressor which are capped with red rubber caps. What do I do with these bottom ports? There are no lines to connect with them. Do I just seal/pinch them off? I am concerned that I am purchasing the wrong compressor.
Guidance would be greatly appreciated before I place my order. Thanks!
#2 Posted : Thursday, May 14, 2009 5:56:32 PM(UTC)
These ports are designed for an oil heating loop which you do not need and can leave as is.
Lawrence430
#3 Posted : Friday, May 15, 2009 4:15:13 PM(UTC)
Lawrence430
Thanks Gene ... You made my day. I thought I could just leave them alone, but no one would/could give me an answer. I called Whirlpool and got nowhere. Checked everywhere on line. Very frustrating.
Thanks again.
Larry
#4 Posted : Friday, May 15, 2009 4:21:18 PM(UTC)
You are welcome Larry. Keep us posted.
