dolemite44149
#1 Posted : Saturday, December 8, 2007 1:12:51 PM(UTC)
dolemite44149
2 problems I need help with.
A) Dishes are getting clean, but takes around 3 hours. Water temp out of kitchen sink is around 125 degrees. Is it reasonable, with such a low tap degree, that it would take this long to cycle through on normal?
B) After the dishes run, there is a brown gunk around the the base of the unit and also behind the silverware tray. Any suggestions as to what they may be/ what I can do to prevent that?
Thank you all in advance for your help!
Greg
#2 Posted : Friday, December 11, 2009 12:34:55 AM(UTC)
Remove the torq screws from the upper pump cover and look for a clogged grill on top of the pump half round cover. Also, check the chopper inside the pump cover, may be clogged or busted. Part # 3039185. If you have a lot of soap residue, dump a gallon of vinegar in the tub and do a normal wash cycle. if grease, you will need to use comet abraise cleanser to remove.
